Installing the SketchUp Importer for Revit
Última actualización: nov 16, 2026•1 min de lecutra.
Before installing the Trimble SketchUp Importer for Revit, you’ll need the following:
  • A Trimble ID with an active SketchUp Pro Scan, SketchUp Pro Advanced Workflows, or SketchUp Studio subscription
  • Autodesk Revit 2026 or 2027
  • Internet access
  • Windows 11 and administrator rights for your operating system
  • The extension also requires .NET Desktop Runtime (.NET 8 for Revit 2026, .NET 10 for Revit 2027) and Microsoft Edge WebView2 Runtime. If they are missing from your installation of Windows, the installer will add the appropriate versions to your device.
Once you’ve reviewed and met the requirements, you can download and install the extension for use in Revit by following these steps:
  1. Close any open instance of Revit on your device.
  2. Download the Trimble SketchUp Importer for Revit installer by clicking the following link: Trimble SketchUp Importer for Revit
  3. Run the installer.
  4. Read the Trimble Offering Terms for Software and Subscriptions and accept them. The installer cannot continue until you click Accept.
  5. Click Install.
  6. Open Revit
  7. Revit will ask if you trust this add-on. Choose Always Load.
  8. Locate the SketchUp tab and ribbon in the Revit interface.
