Trimble SketchUp for Revit Settings
Última actualización: nov 16, 2026•3 min de lecutra.
The settings in the Trimble SketchUp for Revit extension control how the importer places and builds your SketchUp model in your Revit project. These settings will apply to each file you import.
To access the settings, follow these steps:
  1. Open a Revit project.
  2. Make sure you are signed in with your Trimble ID.
  3. On the SketchUp ribbon, click Manage > Settings.
After adjusting and saving these settings, they are saved to your device. If you would like to copy or share them, search your device for the panel-settings.json file in the Trimble SketchUp for Revit files.
Model Settings
Import Level
Import Level controls where imported elements attach in your Revit project. You can designate a specific Level or choose By elevation. If you select By elevation, the object attaches on the highest Level at or below its lowest point. For floors, this is the top surface. For ceilings or roofs, it’s the underside. Only Levels with Building Story selected are used when selecting By elevation. If your project has no Levels, you’ll need to close the settings, add a Level to your project, and reopen settings.
Level Tolerance
Level Tolerance sets how far below a Level an object may start and still count as on that Level. This option will only appear if By elevation is selected.
Curtain Wall
Curtain Wall provides options for every Curtain Wall type loaded in the Revit project. The type of Curtain Wall you select here will be used for every native Curtain Wall. If you don’t make a selection, the importer will use the first Curtain Wall type in the project. A project must contain at least one Curtain Wall type for the importer to work.
Limits
Max Shapes Per Family
This setting limits the amount of shapes each family can hold during the import process. If a family holds more solid shapes than the maximum, it is split into parts. Mesh parts do not count. For very detailed components, select a lower value here.
Texture Storage Limit
The importer stores each texture once. When this limit is passed, the least used textures are removed. A project that used a removed texture stops showing it until you import the model again.
Walls
Separate Layers for Walls
When turned on, this setting turns each material region into its own single-layer wall. A one-face piece becomes a Finish wall, and a solid becomes a Structure wall. When turned off, the largest solid is the wall.
Default Thickness
If your import contains any walls drawn as a single face, or the wall’s thickness is missing or invalid, this setting will give that wall the designated thickness.
