Trimble Creator
Última atualização: ago 21, 2026•2 min leitura.
Trimble Creator is a web-based application used to build the logic that powers a Live Component. After building a Live Component in Creator, you can then use it in your own models, or share it with the SketchUp community on 3D Warehouse.
To get started with Trimble Creator, go to https://creator.trimble.com. After agreeing to Trimble's General Product Terms, Privacy Policy, and Privacy Policy Supplement, you'll be ready to build Live Components.
image trimble creator home
The Trimble Creator interface is made up of two viewer panes. The top pane is a 3D viewer where you can see the live component you are building. The lower pane is where you'll see the graph representing the nodes and connections that determine how your component works.
If you are new to building Live Components, the included Tutorial Browser can walk you through the interface, basic concepts, and first steps you'll need to start building.
image trimble creator tutorial browser
If you run into an issue with the application, you can click Submit feedback at the top of the application, or visit Trimble Creator in the SketchUp forums.
