Shape Types and Exporting Non-Native Elements
Última atualização: nov 16, 2026•3 min leitura.
Not every SketchUp object should become a native Revit element. Furniture, equipment, and context are better represented in a Revit project as Families or Meshes. The four Shape Types in Revit can help you best represent the objects in your SketchUp model when importing it to Revit.
Shape type
What it represents
What it’s best for
Editable in Revit
Hosts doors and windows
Native
A real Revit element (wall, floor, door, window, ceiling, roof, curtain wall)
Wall, slab, door, window, roof, ceiling, curtain wall
Full editing capability
Yes (walls)
Solid Family
A loadable family with free-form solids. Facet lines show on curves.
Column, beam, casework with sharp edges
Can swap or replace
No
Mesh
A loose mesh in the project (DirectShape). Not a family.
Heavy context and entourage
No
No
Mesh Family
A family that holds one mesh. No facet lines.
Chair, table, lamp, curved object, trees, people, cars, terrain, site context, stairs and railings
Can swap or replace
No
With every Shape Type, the following properties of your objects won’t change:
  • Geometry is present with its true shape.
  • Category follows your choice in Select Objects (or the IFC class).
  • Materials come from SketchUp.
  • The element can be scheduled, tagged, and filtered by category.
Native Elements
Native elements are built from the plan, have the thickness and height of your solids, and are editable like any Revit element. They follow rules about solids, face orientation, and thickness.
Families
Families are loaded into the project and placed as instances. Each family has the following properties:
  • Component reuse – Identical component instances share one family. Fifty chairs make one family and fifty instances. Fifty separate groups make fifty families.
  • Naming – The family name is the component name.
  • Level of detail – A family with more than the Max shapes per family setting is split into parts with a default of 75.
  • Parts and materials – Each solid shape has its own material parameter, Part_1_Material, Part_2_Material, and so on, allowing you to remap each one.
  • Tags – Each tag is converted into a subcategory within Object Styles.
  • Nesting – Child components are nested families. Containers, such as IfcSite, IfcBuilding and IfcBuildingStorey, are not nested. Their children import flat.
Meshes
A Mesh is the lightest option. It is one loose object in the project. Meshes have the following properties:
  • Family – None
  • Level – None
  • Type Swap – Cannot be done
  • Materials – As set in SketchUp
Solid and Mesh Families
Solid and Mesh Families support the following properties:
  • View the Family in 3D and in plans
  • Override visibility by category
  • Tagging and scheduling
  • (Solid Families only) Remap material
Solid and Mesh Families do not support the following properties:
  • Parametric editing
  • Can host doors or windows
  • Can join with walls or floors
Object Category Mapping
Each object's category comes from its IFC class. Common categories include:
IFC Class
Revit Category
IfcColumn
Columns
IfcBeam, IfcMember
Structural Framing
IfcFooting, IfcPile
Structural Foundations
IfcFurniture, IfcFurnishingElement
Furniture
IfcLightFixture
Lighting Fixtures
IfcSanitaryTerminal
Plumbing Fixtures
IfcFan, IfcPump, IfcChiller and other plant
Mechanical Equipment
IfcElectricGenerator, IfcElectricMotor
Electrical Equipment
IfcStair, IfcRailing, IfcRamp
Generic Model
Unclassified
Generic Model
When Revit refuses a category for a family, the object goes to Generic Models.
