Using the Analysis Hub Dashboard
Última atualização: ago 21, 2026•1 min leitura.
The Analysis Hub dashboard is where  you can view and manage each analysis you’ve performed, create a new one, or start again with a new model snapshot.
image analysis hub dashboard window
At the top of the window you’ll see the scene used for your model snapshot, when it was first analyzed, the last update that was made, and its status.
In the dashboard you can perform the following actions:
  • Creating a New Analysis – Clicking Create New Analysis takes you to where you can select a new type of analysis.
  • Deleting an Analysis – Each analysis you’ve performed appears as a tile on the dashboard. Clicking Delete Analysis (icon) removes that analysis file.
  • Creating a New Model Snapshot – Clicking Add Model Snapshot (icon) to create a new snapshot from a different scene.
  • Review Current Model Snapshots – Each scene you’ve used as a snapshot will be listed on the right side of the dashboard. Click the scene name to review each analysis done for that scene.
