Glazing Ratio Strategies Explained
Última atualização: ago 21, 2026•9 min leitura.
This article explains what the strategies in the Glazing Ratio feature are comprised of, specifically:
  • What the different glass types are and their assumed properties.
  • What "metal - broken", "metal - unbroken" and "non-metal" frames are.
  • What "partial", "substantial" and "extensive" shading is.
  • What "basic", "good" and "great" glazing solar control is.
Related articles:
These strategies are found in the glazing ratio feature (see example below).
Why we've used generic names for strategy components.
This feature aims to help associate a recommended maximum amount of glazing by orientation with different facade strategies that might be employed to improve facade performance.
At PreDesign, most projects will not know what specific products they will use. However for many projects, budgeting from the start is important. These strategies can be used to help get a broad idea of the cost and aesthetic implications of using different amounts of glazing on different orientations.
One way to use this feature is to identify what you would need for the target glazing ratio and then use this information to create an outline set of requirements / briefing specification by orientation for your facade.
How we broke up the facade components
The facade assembly is broken up into 4 elements in this feature.
Elements affecting the glazing assembly insulation:
  • Glazing type
  • Frame type
Elements affecting the glazing assembly solar control:
  • Shading type
  • Glazing solar control
    Why isn't infiltration considered here?
    Infiltration is the phenomenon of air leaking into and out of the building through the facade, which can contribute to heat gain, heat loss and humidity issues. Generally speaking the amount of glazing you have is not associated with the infiltration rate, which is why it's not covered here.
What the assembly looks like
We've used real products to create assemblies that attempt to mimic in a generic way how a design might work. The assembly includes a frame and the assembly properties were calculated using LBNL's Window 7.7 software.
Glazing Types
We characterise 6 different glazing types in the feature. The table below describes what is assumed in terms of properties and what other things (if any) it can be a proxy for (at pre- design).
Strategy
What it is
Center-of-glass U-value in calculation (W/m2/K)
OK to proxy for
Single Glazed
A single pane of 6mm glass
5.6
Any single-paned glass or perspex/ plastic (any thickness). Laminated glass without a low-e layer inside.
Laminate
Two adjacent 6mm glazing panes with a low-e coating in between
5.0
Any laminated glass with a low-e layer inside.
Double Glazed Argon
Two 6mm pieces of glazing with a 12mm an argon-filled gap between them.
2.5
Any double glazed unit with any type of gap but without a low-e coating
Double Glazed Low-e
Two 6mm pieces of glazing with a 12mm gap and a low-e coating on surface 2.
1.7
Any double glazed unit with any type of gap with a low-e coating
Triple Glazed Argon
Three 6mm pieces of glazing with a 12mm an argon-filled gap between each.
1.6
Any triple glazed unit with any type of gap.
Triple Glazed Low-e
Three 6mm pieces of glazing with a 12mm gap and a low-e coating on surface 2.
1
Any triple glazed unit with a low-e coating
Frame Types
We characterise 3 frame types in PreDesign. The table below describes what is assumed in terms of properties and what other things (if any) it can be a proxy for (at pre- design).
Strategy
What it is in the calculation
Frame material U-value (W/m2/K)
OK to proxy for
Unbroken Metal
A window frame, made from aluminium, that does not have a thermal break.
15
Any metal window frame that does not have a thermal break.
Broken Metal
A window frame, made from aluminium, that incorporates a thermal break.
5.6
Any metal window frame with a thermal break
Non-metal
A window frame made from PVC.
1.7
Any plastic, wood or composite window frame made from a non-conductive material.
Shading Types
We characterise 4 shading types in PreDesign. The table below describes what is assumed in terms of properties and what other things (if any) it can be a proxy for (at pre- design).
Strategy
Where to see examples
No Shading
Glazing has no external shading.
Each strategy on the shading feature shows the % of overheating / detrimental sun blocked by that strategy for each orientation (see below).
Partial Shading
Glazing has a shading system blocking at least 25% of detrimental sun.
Substantial Shading
Glazing has a shading system blocking at least 50% of detrimental sun.
Extensive Shading
Glazing has a shading system blocking at least 75% of detrimental sun.
For example, the image below shows 4 different shading strategies on the south facade of a building in Boulder, Colorado.
  • Automated Blinds block more than 75% of overheating sun, so it is considered an extensive shading strategy for this facade.
  • Overhang blocks over 50% of overheating sun, so it's considered a substantial shading strategy.
  • Fins and No shading block less than 25% of overheating sun, so both are considered to be equivalent to no shading.
Glazing solar control types
We characterise 3 types of glazing solar control in PreDesign.
Glazing Solar Control is assessed relative to the glazing used. In other words, "great" solar control for single glazing (most likely some kind of heavy tint or frit) would still perform worse than a "basic" solar control level for a good low-e coating on a low-e double glazed unit.
This was done so the terms relate meaningfully to the unit as a whole.
The table below describes what is assumed in terms of SHGC (solar heat gain coefficient) for each glass type's "basic, good, best" option with a broken metal frame. Non-metal frames have slightly lower SHGC-values reflecting the thicker frame. Un-broken frames have higher values.
Assumed center of glass solar heat gain coefficient (SHGC)
Glazing type
Basic
Good
Great
Single Glazed
0.77
0.57
0.48
Laminate
0.66
0.53
0.34
Double Glazed
0.69
0.47
0.38
Double Glazed low-e
0.41
0.28
0.22
Triple Glazed
0.57
0.41
0.32
Triple Glazed low-e
0.29
0.23
0.21
How you get an SHGC depends on the type of glass you're starting with, but strategies such as tinting, low-e coatings and fritting can all reduce the solar heat gain coefficient.
Lookup Table
Strategy Name
Glazing Type
Glazing Performance
Frame
Proposed Glazing Assembly U-value (W/DegC/m2)
Proposed Effective Assembly SHGC
Single Glazed
Single
Basic
Metal (broken)
5.6
0.77
Single Glazed
Single
Good
Metal (broken)
5.5
0.57
Single Glazed
Single
Great
Metal (broken)
5.5
0.48
Laminate
Laminate
Basic
Metal (broken)
5.1
0.66
Laminate
Laminate
Good
Metal (broken)
5.1
0.53
Laminate
Laminate
Great
Metal (broken)
5.1
0.34
Double Glazed Argon
Double Glazed Argon
Basic
Metal (broken)
3.1
0.69
Double Glazed Argon
Double Glazed Argon
Good
Metal (broken)
3
0.47
Double Glazed Argon
Double Glazed Argon
Great
Metal (broken)
3
0.38
Low E Double Glazed
Low E Double Glazed
Basic
Metal (broken)
2.4
0.41
Low E Double Glazed
Low E Double Glazed
Good
Metal (broken)
2.4
0.28
Low E Double Glazed
Low E Double Glazed
Great
Metal (broken)
2.4
0.22
Triple Glazed Argon
Triple Glazed Argon
Basic
Metal (broken)
2.3
0.57
Triple Glazed Argon
Triple Glazed Argon
Good
Metal (broken)
2.3
0.41
Triple Glazed Argon
Triple Glazed Argon
Great
Metal (broken)
2.3
0.32
Low E Triple Glazed
Low E Triple Glazed
Basic
Metal (broken)
1.9
0.32
Low E Triple Glazed
Low E Triple Glazed
Good
Metal (broken)
1.9
0.26
Low E Triple Glazed
Low E Triple Glazed
Great
Metal (broken)
1.9
0.21
Single Glazed
Single
Basic
Non-metal
4.9
0.73
Single Glazed
Single
Good
Non-metal
4.9
0.53
Single Glazed
Single
Great
Non-metal
4.9
0.44
Laminate
Laminate
Basic
Non-metal
4.4
0.61
Laminate
Laminate
Good
Non-metal
4.4
0.49
Laminate
Laminate
Great
Non-metal
4.4
0.31
Double Glazed Argon
Double Glazed Argon
Basic
Non-metal
2.5
0.65
Double Glazed Argon
Double Glazed Argon
Good
Non-metal
2.5
0.43
Double Glazed Argon
Double Glazed Argon
Great
Non-metal
2.5
0.35
Low E Double Glazed
Low E Double Glazed
Basic
Non-metal
1.7
0.37
Low E Double Glazed
Low E Double Glazed
Good
Non-metal
1.7
0.25
Low E Double Glazed
Low E Double Glazed
Great
Non-metal
1.7
0.2
Triple Glazed
Triple Glazed
Basic
Non-metal
1.8
0.53
Triple Glazed
Triple Glazed
Good
Non-metal
1.8
0.37
Triple Glazed
Triple Glazed
Great
Non-metal
1.8
0.29
Low E Triple Glazed
Low E Triple Glazed
Basic
Non-metal
1.4
0.29
Low E Triple Glazed
Low E Triple Glazed
Good
Non-metal
1.4
0.23
Low E Triple Glazed
Low E Triple Glazed
Great
Non-metal
1.4
0.18
Single Glazed
Single
Basic
Metal (not broken)
6.9
0.83
Single Glazed
Single
Good
Metal (not broken)
6.8
0.62
Single Glazed
Single
Great
Metal (not broken)
6.8
0.54
Laminate
Laminate
Basic
Metal (not broken)
6.4
0.71
Laminate
Laminate
Good
Metal (not broken)
6.4
0.58
Laminate
Laminate
Great
Metal (not broken)
6.4
0.4
Double Glazed Argon
Double Glazed Argon
Basic
Metal (not broken)
4.3
0.75
Double Glazed Argon
Double Glazed Argon
Good
Metal (not broken)
4.3
0.52
Double Glazed Argon
Double Glazed Argon
Great
Metal (not broken)
4.3
0.43
Low E Double Glazed
Low E Double Glazed
Basic
Metal (not broken)
3.5
0.41
Low E Double Glazed
Low E Double Glazed
Good
Metal (not broken)
3.5
0.33
Low E Double Glazed
Low E Double Glazed
Great
Metal (not broken)
3.4
0.28
Triple Glazed
Triple Glazed
Basic
Metal (not broken)
3.6
0.62
Triple Glazed
Triple Glazed
Good
Metal (not broken)
3.6
0.46
Triple Glazed
Triple Glazed
Great
Metal (not broken)
3.6
0.38
Low E Triple Glazed
Low E Triple Glazed
Basic
Metal (not broken)
3.2
0.38
Low E Triple Glazed
Low E Triple Glazed
Good
Metal (not broken)
3.2
0.31
Low E Triple Glazed
Low E Triple Glazed
Great
Metal (not broken)
3.2
0.26
