Troubleshooting the SketchUp Importer for Revit
The following sections can help if you encounter issues using the SketchUp Importer for Revit.
Message | What to do |
Could not generate a preview for this model. | Save the file in SketchUp again and retry. |
Could not convert the SketchUp file. Check the log for details. | Check the log. |
Could not save the converted file. Check available disk space and permissions. | Free disk space, check Temp permissions. |
Invalid or unsupported TrimBIM file. | Save the file again. |
Viewer viewport could not be created. | Update your graphics driver and restart Revit. |
**Preview failed: ** | Send the log to support. |
Please check at least 1 object from the list to import | Check at least one object. |
Reason Shown | Cause | What to do |
Revit could not modify the document (it was read-only or temporarily disabled during import)... | The project is read-only, or Revit is in an edit mode. | 1. Finish any edit. 2. Make sure the file is not read-only. 3. Reopen the project and import again. |
An imported element name conflicts with existing content in the document. | A family or type name already exists. | 1. Rename the component in SketchUp. 2. Import again |
Revit rejected part of the geometry during import. Check the log for details. | Revit refused some geometry. | 1. Open the log. 2. Find the object. 3. Fix its solid, or set it to Mesh. |
The file appears to be invalid or corrupted and could not be read. | The .trb is damaged | 1. Save the .skp again. 2. Import again. |
Template files are missing... | Family templates are missing from the installation. | Run the installer again. |
The import took too long and was stopped. | A time-out | Import fewer objects, or use Mesh for dense context. |
The file could not be found. | The file was moved or deleted. | Select the file again. |
The SketchUp conversion components are missing... | Converter files did not load. | Run the installer again. |
The geometry of these objects could not be built: 'A', 'B'... and N more. | Named objects failed (up to five). | 1. Find the named objects in SketchUp. 2. Run Solid Inspector. 3. Import again, or set them to Mesh. |
The category of these objects could not be assigned: ... | Revit refused the category. | Choose another category in Select Objects. |
Notice | Cause | What to do |
Some geometry was simplified due to boundary issues in the SketchUp model. | Faces were removed (not planar, self-intersecting, too small), holes were filled. | Clean the objects, then import again. |
**roof object(s) could not be built as editable Revit roofs and were imported as meshes in the Roofs category.** | The roof failed a shape check. | Simplify the roof to one closed slab of even thickness with no duplicate faces and consistent face orientation. See the Modeling Playbook. |
**curtain wall(s) could not be built as native Revit curtain walls and were imported as generic objects instead.** | The parts do not form a regular grid, or Revit refused. | Use a regular grid, or draw the wall as surfaces and thin solids. See the Modeling Playbook. |
**object(s) were imported as Generic Models because Revit does not allow for families.** | A system category was chosen for a family | Choose another category, or Native or Mesh |
What you see | Likely cause | What to do |
A window or door has no opening in the wall | The window or door was unhosted: no overlap, no native wall, set to Mesh, or on a curved wall. | Overlap the wall or door onto the wall by at least 10 mm, keep the wall Native. |
A wall became a generic family | It was not a closed solid. | Check Volume and fix the solid. |
A floor is missing or empty | No horizontal face, or too many faces. | Add a flat top face, or raise Max faces per floor. |
Everything sits on one Level | Import level is a single Level. | Choose By elevation and create Levels first. |
A mesh has no Level | Meshes cannot have a Level. | Choose Native, Solid Family, or Mesh Family. |
A material looks wrong | A Revit material with the same name already exists | Rename it in SketchUp, or use Map Materials (not for meshes). |
A finish is on the wrong side | Face orientation | Reverse the faces. |
Many tiny families | Many separate groups | Turn repeated groups into components. |
Nothing changed on a second import | Elements from the earlier import are skipped | Delete the old elements first. |
A window sill height is wrong | No Sill Height property | Add the property. A number is millimeters. |
Guides, text or an image are missing | The guides, text, or image was not imported. | The guides, text, or image are dropped without a warning. Redraw them in Revit. |
An unexpected Generic Model appeared | A SketchUp dimension, or loose geometry | Delete dimensions and loose geometry before importing. |
The SketchUp Importer for Revit logs every attempt to import a file, even if the import fails or is interrupted. Reviewing these logs can help determine why there was an issue with your import.
To access your logs, selectInfo > Log folder in the extension. You can also find the logs in a .log file in the following locations:
File | Location |
Current log |
Older logs |
The ten most recent events are in the RevitExporter.log file. Older events appear in the same folder with a date and time added to them.
The logs provide the following information:
Prefix | What it tells you |
| One summary line: Outcome, elements, failures, duration, fallbacks, holes |
| The settings used |
| Revit warnings that were Hidden, counted by kind |
| Door and window outcomes: Hosted, freeform, skipped, lost |
| One line per door or window: The host wall and the reason if it was not hosted |
| Where a window's sill height came from |
| Wall events and fallbacks |
| Curved wall results |
| Floor events |
| Curtain wall results |
| Roof results and rejection reasons |
| Level assignment issues |
| Texture handling |
Other files you may need include:
Item | Location |
Import and panel settings |
Texture store |
Temporary downloads |
Contacting Support
You can contact support through Info > Contact support from the extension or https://my.trimble.com/s/contactsupport. When contacting support, provide the following information:
Your latest log files.
The file you are trying to import.
The Revit and SketchUp versions you use.
A detailed description of the issue.
