Importing Revit Files to SketchUp
The best way to import Revit files into SketchUp is with the Revit Importer extension. The import process transfers geometry, materials, textures, building levels, tags, and critical BIM data.
To use the Revit Importer, you’ll need the following:
A SketchUp Pro Scan, SketchUp Pro Advanced Workflows, or SketchUp Studio subscription
A supported version of SketchUp
A Revit file created with at least Revit 2011, up to the current version of Revit supported by the Revit Importer
SketchUp for Desktop on Microsoft Windows
The Revit Importer is an extension available for download from Extension Warehouse. When you download SketchUp, the Windows installer provides the option to include the extension as part of your installation.
The following articles can help you learn more about importing Revit files:
Revit Version Compatibility – Information about which versions of Revit the importer is compatible with and why the importer may not be compatible with the latest version.
Preparing a Revit Files for SketchUp – A few things you should consider before importing your Revit file.
Importing a Revit File – How to use the Revit Importer to import a file into SketchUp.
Phases in Revit Importer – More information about Revit phases and how they can influence what appears in your imported file.
Importing Revit Metadata – Learn more about what happens when you choose to import Revit metadata.
Materials and Textures in Imported Files – A few things to know when importing Revit materials and textures.
Alternative Revit to SketchUp Options – For those who don't have a subscription with access to the Revit Importer, we've compiled a few other options that allow you to work with Revit inside SketchUp.
