File Management
SketchUp for Web saves your models to Trimble Connect, Trimble's cloud-based common data environment and collaboration platform. Here’s all the information you need to use Trimble Connect to manage the files you create in SketchUp for Web:
  • Opening Files - You can open files from the SketchUp for Web Home page, Trimble Connect, or a file saved to your device.
  • Saving and Downloading Files - SketchUp for Web helps you save updates to your models through auto-saves to Trimble Connect. You can also retrieve backups from your browser’s cache and through SketchUp for Web’s full revision history.
  • Sharing - Through SketchUp’s collaboration tools, you can share your models with other users.
Importing and Exporting Non-SketchUp Files
SketchUp for Web doesn't have unrestricted access to your device’s file system. The following special rules apply when you import and export 3D model files created in applications other than SketchUp:
When importing .dae and .3ds files:
  • Create a folder that includes all texture images.
  • Create a zipped archive containing that folder and the model.
  • The model file must include the proper paths to find the texture images before zipping the file.
  • Use the import options in SketchUp for Web to import the zipped files.
When exporting .dae, .3ds, .wrl, .fbx, .xsi, .obj:
  • SketchUp for Web will create a zipped archive file.
  • The file must be unzipped before exporting to another application, including a separate instance of SketchUp.
Supported File Types
Following are the SketchUp for Web supported file types for free users and SketchUp subscribers.
Features
Free
Subscription
Import
.skp, .jpg, .png, .stl, .dwg, .dxf, .dae, .kmz, .3ds, .dem, .ddf
Export
.stl, .pdf
.stl, .pdf, .dwg, .dxf, .dae, .kmz, .3ds,  .fbx, , .obj
