Solid Tools
Last updated: Sep 29, 2026•1 min read.
In SketchUp, a solid is any 3D component or group with a finite closed volume without any missing faces or faces that do not meet at an edge. With SketchUp's Solid Tools you can create new shapes by combining or cutting one solid with another.
First, make sure the geometry you want to manipulate is a solid. Select the group or component and check the Entity Info panel. If your selection is a solid, you'll see confirmation there.
To help you start creating intricate geometry and complicated shapes, SketchUp provides the following Solid Tools:
Name
Icon
Description
Intersect
Remove all geometry from two solids except where they overlap.
Outer Shell
Combines multiple solid objects removing any unwanted interior geometry.
Split
Creates a solid third object representing the geometry where two other solids interact, subtracting that space from the original solids.
Subtract
Subtracts one solid object from another and removes it from your model.
Trim
Remove one solid object from another without removing it from your model.
Union
Combines two or more solids into a single form preserving any voids where those objects overlap.
