Extruding with Follow Me
Last updated: Nov 11, 2026•4 min read.
The SketchUp Follow Me tool ( Follow 20Me.png ) leads a face along a path to create a 3D shape. Follow Me is ideal for modeling finishing details that follow a perimeter or edge, such as crown molding or gutters. It also makes easy work of modeling lathed objects like a spindle, and curved vessels, such as a bowl or a vase.
There are two versions of Follow Me—the basic Follow Me tool (icon) and the Procedural Follow Me tool (icon).
With the basic version of the tool, extruded shapes and the paths you have them follow are entities like any other shapes you draw in SketchUp. The edges and faces created with Follow Me must be edited individually. If you need to change something you often need to redo the entire operation.
With the Procedural Follow Me, the path and the extruded shape become a non-destructive procedural component you can edit and manipulate just like other components in SketchUp.
Using Follow Me
Both classic Follow Me and Procedural Follow Me use two basic workflows—automatic or manual extrusion. Automatic extrusion requires you to select a path before activating Follow Me, while the manual extrusion method starts with activating the tool first.
Automatic Extrusion
Follow these steps to automatically extrude a face:
  1. Determine the geometry in your model you want to use as a path.
  2. Draw a profile of the face you want to extrude perpendicular to the path. The profile doesn't need to be connected to the path, it just needs to be perpendicular.
  3. Using the Select tool (Select.png), select a continuous set of edges that represents the path. Use Shift as a modifier to add multiple edges if needed.
    image follow me automatic extrusion
  4. Activate the Follow Me tool (Follow 20Me.png). The edges selected in the previous step won’t remain highlighted but remain selected.
  5. Click the profile you created. The Follow Me tool extrudes that profile along your pre-selected path.
    image follow me automatic result
Manual Extrusion
To extrude a face without selecting edges first, follow these steps:
  1. Determine what geometry in your model to use as a path.
  2. Draw a face or profile to follow the path. Make sure that this profile is perpendicular to the path.
  3. Activate the Follow Me tool (Follow 20Me.png).
  4. Click and drag the face that you created along the path, touching the mouse pointer to the edge you are following. As you drag, SketchUp highlights your path in red.
  5. At any time, press ESC to start over.
  6. When you reach the end of the path, click again to complete the operation.
Modeling a Cylindrical Shape
You can use the Follow Me tool to create a symmetrical cylindrical shape, like one created by a lathe. To create a cylindrical shape, following these steps:
  1. Activate the Circle tool (Circle.png) and draw a circle.
  2. Draw a cutaway representing half of the final shape. Make sure the cutaway forms a face and that all segments connect. If needed, you can draw a larger version of your cutaway and use the Scale tool to adjust it to the proper size.
  3. Align the cutaway with the center of the drawn circle.
    image follow me circle
  4. Select the circle.
  5. Activate the Follow Me tool (Follow 20Me.png) and click the face of the cutaway. SketchUp creates your finished shape.
    image follow me circle result
Procedural Follow Me Components
When using Procedural Follow Me (icon procedural follow me), the Follow Me operation creates a Procedural Component. When you complete a successful Follow Me operation, you’ll see the component selected.
gif follow me creation
With this component, you can adjust the shape you used to perform the action and edit the path without changing any other geometry in your model.
gif follow me editing
Unlike other Procedures, Follow Me doesn’t have any special controls in Entity Info.
