Shadows Panel
Last updated: Sep 29, 2026•1 min read.
SketchUp for iPad's Shadows ( go icon shadows panel.png ) panel can help designate how parts of your model cast their shadows or even see how the sun would cast shadows on or around a geolocated model.
The Shadows panel helps you control shadows in your model using the following options:
  • Shadows - Toggles used to turn shadows off or on, and adjust how they are cast:
    • On Face - Cast shadows on other faces.
    • On Ground - Cast shadows on the ground plane.
    • From Edges - Controls whether edges that are not associated with a face cast a shadow
    • Use sun for shading - When toggled on, SketchUp's simulated sun shades parts of your model even if shadows are toggled off.
  • Timezone - A drop-down box allowing you to choose a specific time zone.
  • Time/Date - Sliders allowing you to select a specific time or date.
  • Light/Dark - Sliders controlling how light illuminated areas appear and how dark shaded or shadowed areas appear.
  • Add location - Opens a tool to help you geolocate your model.
For more information on using shadows in your model, see Casting Real-World Shadows .
