Adjusting Images
Last updated: Nov 2, 2026•2 min read.
The Image Adjustments panel lets you adjust raster and hybrid renders and image assets. These adjustments occur directly within your viewport, streamlining your workflow by removing the need for external image editors.
image layout image adjustment panel
The panel contains several controls to fine-tune images in your document:
  • Opacity – Adjust the transparency of your images or SketchUp model viewports.
  • Brightness & Contrast – Correct exposure issues or enhance the visual impact of your site photos and renders.
  • Hue & Saturation – Tweak color balance or  desaturate images to create stylized grayscale documentation.
  • Reset Controls – Revert changes with individual reset buttons for each setting, or the Reset All option to return to the original image state.
To adjust a SketchUp Model viewport or an image, follow these steps:
  1. Click Window > Default Tray > Image Adjustments to open the Image Adjustments panel, if it isn’t already open.
    image layout image adjustment panel path
  2. Select the SketchUp model viewport or image you want to adjust.
  3. Use the image adjustment sliders to modify the individual settings.
    image layout image adjustment settings
You can hide each setting using the arrow to the right of its name in the panel. To reset a setting to its original value, click Reset.
