Secondary Email
Last updated: Sep 4, 2026•1 min read.
One of the available Multi-Factor Authentication (MFA) methods you can choose from is to use a secondary email. This email must be different from the email associated with your Trimble ID. When you choose to use a secondary email as your MFA method, a code will be sent to that email address each time you log in.
Setting Up a Secondary Email
To set up a secondary email:
  1. Go to myprofile.trimble.com and sign in using your Trimble ID.
  2. Select Secondary Email from the available MFA options.
  3. Enter the email you want to use and click Next.
  4. Check that email for a message with a verification code.
  5. Enter the code and click Submit.
Logging In with a Secondary Email
After setting up secondary email as your MFA method, log in using the following steps:
  1. Enter your email address and password and select Next.
  2. Trimble will send a verification code to your secondary email.
  3. Enter the verification code and select Submit.
