Preset Prompts
Last updated: Aug 21, 2026•2 min read.
Crafting a text prompt for your generated images can seem a bit complicated. To help you generate the stunning visuals you want without getting a degree in prompt engineering, AI Render offers several preset prompts using both regular and negative prompts. Each preset prompt was designed to generate a certain look and feel in your AI-generated output.
To access prompts, click Parameters ( icon sliders.png ) in the text field. The default preset prompt is Auto.
You can then use the text box provided to add in the specific instructions you want AI Render to follow. Once you’ve generated output you can then use the Auto preset along with additional text prompts to further refine and edit your generated image.
To select another preset prompt, click where your current prompt appears to view a list of available presets.
To help you understand the preset prompts available in diffusion, here’s a bit more information about each option:
Name and Thumbnail
Description
Auto
image ai auto
Generates a prompt based on the contents of the current model or image that aims to preserve the materials, geometry, and camera angle of the original.
Exterior Photorealistic
Photorealistic rendering ideal for outdoor architecture.
Interior Photorealistic
Daylight photorealistic rendering, ideal for interior design.
Aerial Masterplan
Ideal for birds-eye aerial views, and landscape renderings
Pencil Sketch
Black and white hand-drawn pencil sketch style.
Watercolor
Watercolor artistic style with soft brush strokes and hand-drawn linework.
Illustration
Post digital illustration, simulating paper cut-outs, pastel colors, and flat textures.
Physical Model
Turn your model into a wooden physical architecture model.
