Creating and Editing Shortcuts
Last updated: Oct 21, 2026•2 min read.
You can create and shortcuts in the Shortcuts section of Preferences. There are a few limitations to what you can do with shortcuts. Here are some guidelines to help you understand what you can and can’t do:
  • You can’t start with a number. Numbers are reserved for some very specific commands or for adjusting measurements.
  • You can use modifier keys. Shift, Alt (Windows)/Option (MacOS), Ctrl (Windows)/Command (MacOS) can all be used in combination with other inputs.
  • You can’t use shortcuts reserved by your operating system. If you try to use a shortcut already in use by your OS, SketchUp will let you know.
  • You can reassign existing default shortcuts. SketchUp assigns shortcuts to a few commands by default. You can always change these default shortcuts to something that works better for you.
The Shortcuts section of Preferences contains the following sections:
  • Function – A list of each tool or command available in SketchUp.
  • Assigned – After selecting a tool or command in the Function section, the assigned shortcut appears here.
image sketchup preferences shortcuts
To find a specific tool or command, use the search bar at the top or enter a keyword to filter what you see listed in the Function section. For example, typing “zoom” filters the available tools and commands to only list Camera/Zoom, Camera/Zoom Extents, Camera/Zoom to Photo, and Camera/Zoom Window.
After locating the function you want to assign a shortcut to, you can add one or edit its existing shortcut by following these steps:
  • Select the command to highlight it. If the selected command already has an assigned shortcut, that shortcut appears under Assigned on the right side of the window.
  • Type the shortcut you want to assign to the command in the Add Shortcut box.
  • Click (plus icon) to add your shortcut.
  • If the shortcut you enter is already assigned to another function, a warning will appear. Click Keep Original to continue or Replace to save the new shortcut.
  • Repeat these steps until you’ve assigned all the shortcuts you want.
To reset all shortcuts to the default settings, click Reset All.
