Generate Object
Last updated: Oct 28, 2026•1 min read.
Adding realistic 3D assets to your model can be time-consuming. Even if you find an object you like in 3D Warehouse, it may not match the vision for your design. With Generate Object, you can use SketchUp AI to create 3D assets with photoreal materials based on an image or text prompt.
Using Generate Object costs 30 Trimble Credits. Credits are deducted from your total once the AI Assistant generates the object.
To get started with Generate Object, take a look at the following articles:
Image Object Generation – A guide to generating an object using an image.
Text Prompt Object Generation – A guide to generating an object using an image created with a text prompt.
Generated Object Gallery – How to manage your generated objects in the Gallery.
