Plan Upgrades and Downgrades
Last updated: Sep 17, 2026•4 min read.
SketchUp offers several different subscription options, each with its own benefits. SketchUp Go and SketchUp Pro offer both annual and monthly plan options. SketchUp Pro Advanced Workflows, SketchUp Pro Civil Contractor, SketchUp Pro Scan, and SketchUp Studio are only available as annual subscriptions.
The Trimble Admin Console and SketchUp Account Management Portal (AMP) provide the tools you need to change your current plan to one that best fits your needs.
For more information about each SketchUp subscription plan, including features and pricing, see Plans and Pricing.
My Plan Type
I Want To...
How It Works
Annual Plan
Upgrade my Annual Plan
After purchasing your new plan, SketchUp applies a prorated amount from the original plan to the cost of the upgraded plan. New features will be available immediately.
Annual Plan
Downgrade my Annual Plan
After purchasing your new plan, the new plan will take effect after the end of the current subscription period. You can still use features in your current plan until the renewal date.
Annual Plan
Change from Annual to Monthly
Turn off auto-renew and only purchase a new monthly plan at the end of your annual subscription period to avoid multiple charges.
Monthly Plan
Change to an Annual Plan
Turn off auto-renew for the current monthly plan then purchase a new annual subscription. Auto-renew must be turned off to avoid multiple charges.
Monthly Plan
Upgrade my Monthly Plan
After purchasing your new plan, the new subscription will be prorated for the rest of the month and begin immediately.
Monthly Plan
Downgrade my Monthly Plan
After purchasing your new plan, the new subscription will take effect at the beginning of the next month. You can continue using your current subscription features until then.
For a walkthrough on how to change your subscription plan, see the article appropriate to the platform you use to manage your account:
When you change your plan, there are a few things to keep in mind depending on your current plan and what plan you are changing to.
Upgrading an Annual Plan
When upgrading from one annual subscription plan to another one with more features, a prorated amount from the original plan will be applied to the cost of the upgraded plan based on the term date. This prorated amount appears during checkout. The features from your new subscription will be available immediately after purchase. If the new subscription benefits aren’t immediately available, log out and log back in.
Downgrading an Annual Plan
Changing your plan to a subscription with less features will only take effect after the end of the current subscription period. When changing your plan, make sure auto-renew is on. Until your auto-renew date, you can continue to use the features of your current subscription. On the auto-renew date, the plan will then renew using the new downgraded plan's price.
Changing from Annual to Monthly
Changing your subscription plan from an annual plan to a monthly plan should only be done at the end of the subscription term to avoid multiple charges. To make sure you aren’t charged again for an annual subscription, the account owner must turn off auto-renew for the current annual plan before purchasing the new monthly subscription. If auto-renew is on, you may be charged for both subscriptions and may not be eligible for a refund on the continuing annual subscription. For more information, see Refunds and Cancellations.
Changing from Monthly to Annual
To upgrade from a monthly plan to an annual plan, the account owner must turn off auto-renew for the current monthly plan and purchase a new annual subscription from the Plans and Pricing page. If auto-renew is on, you may be charged for both subscriptions and may not be eligible for a refund on the continuing annual subscription. For more information, see Refunds and Cancellations.
Upgrading a Monthly Plan
Monthly plans are only available for SketchUp Go and Pro. If you would like to upgrade to SketchUp Pro Scan, SketchUp Pro Advanced Workflows, SketchUp Pro Civil Contractor, or SketchUp Studio, see Changing from Monthly to Annual. When upgrading from SketchUp Go Monthly to SketchUp Pro Monthly, the new subscription will be prorated for the rest of the month and begin immediately.
Downgrading a Monthly Plan
Changing your plan to a subscription with fewer features will only take effect after the end of the current subscription period. When changing your plan, make sure auto-renew is on. Until your auto-renew date, you can continue to use the features of your current subscription. On the auto-renew date, the plan will then renew using the new downgraded plan's price.
