The Analysis Viewer
Last updated: May 19, 2026•2 min read.
The Analysis Viewer provides a 3D environment where you can interact with your analysis results.
image-analysis-viewer-window
The top of the window lists the scene name for the analysis along with the type of analysis you performed.
image-analysis-viewer-top-window
You can change the view of your model with the following options:
  • Top View (icon-top-view) displays a 2D top-down view using parallel projection.
  • Iso View (icon-iso-view) displays a 3D isometric view.
  • Using the dropdown, you can select a building floor in your model and narrow the view to only show that floor.
The left side of the window offers a toolbar containing the following tools:
image-analysis-viewer-left-window
  • Select (Select.png) – The default tool for interacting with your analysis.
  • Section Plane (icon-section-plane-tool.png) – Activate and click a face on the model to create a section. You can then use the tool to adjust the view or delete a section if needed.
  • Zoom Extents (Zoom-20Extents.png) – Resets the camera to show the entire uploaded model.
The right side of the window contains the following panels to help you adjust your results:
image-analysis-viewer-right-window
  • Analysis Settings – Settings specific to each analysis allowing you to change the criteria used to generate your analysis data and adjust the settings for the simulation.
  • Spaces – Lists all floors and spaces in the model with the option to toggle each on or off.
  • Materials – Lists all materials in the model and how their properties are used in the simulation.
  • Display – Settings allowing you to toggle on or off parts of your model, how faces appear in the simulation, and what units of measurement are used.
  • Model Info – The model’s geolocation information.
The bottom of the window provides a legend appropriate to your chosen analysis type to help you interpret your analysis data.
image-analysis-viewer-bottom-window
After performing an analysis, clicking Home (icon-home.png) on the Analysis Viewer opens the Analysis Hub dashboard where you can view and manage each analysis you’ve performed, create a new one, or start again with a new model snapshot.
image-analysis-hub-dashboard-window
