Trimble Connect in SketchUp for iPad
Last updated: Aug 21, 2026•1 min read.
SketchUp for iPad features full integration with Trimble Connect. You can add any file you create in SketchUp for iPad to your Trimble Connect projects, or access and edit existing models you’ve saved to Trimble Connect.
When viewing your Recent Files on the home screen, each file includes an icon that tells you where that model is saved:
- Locally saved file –
- Saved to Trimble Connect –
If you want to move a locally saved file to Trimble Connect, tap the menu icon (
) and select Save to Connect. In the window that appears, choose the project you want to add the file to, and tap Save to save it.
You can access any file saved to a Trimble Connect project from the Trimble Connect tab on the Home screen.
Once you’ve saved to Trimble Connect, you can use SketchUp’s collaboration tools to share your work with peers and stakeholders. For more information, see Sharing a Model.
