Opening Files
Dernière mise à jour : sept. 29, 2026•2 min lecture.
When you launch SketchUp for Web you have a few ways to open models you have previously worked on.
Recent Files
The Recent Files section of the SketchUp for Web Home page contains any recently opened model that still exists in your browser cache.
image web recent files
To open a file in the Recent Files section, click the file's tile.
Opening from Trimble Connect
SketchUp for Web saves your model in Trimble Connect by default. To open files from Trimble Connect, follow these steps:
  • Select Trimble Connect from the left side of the Home page of SketchUp for Web.
  • Choose the project you saved your model to.
  • Select the model you want to open.
Trimble Connect’s Revision History
Every time you save a model, and every time SketchUp for Web auto-saves, Trimble Connect creates a new version of your model and retains the old ones. Going back to an older version of your model can be helpful if:
  • Your model becomes corrupted.
  • You add geometry or components that make your model difficult to operate.
  • You want to revert back to an earlier, simpler version of your model.
To access the revision history for a model, navigate to that model in either the Home tab or Trimble Connect project for the model. Open the file options menu and select History. A sidebar showing each saved older version of your model appears on the right-side of the page.
