Creating a Template in LayOut
Dernière mise à jour : sept. 29, 2026•2 min lecture.
If you consistently work from a customized LayOut document design, you can save your basic document framework as a template. Templates are also a great way to ensure documents use the same company branding, titleblocks, or project elements.
When you save a LayOut document as a template, the template contains everything that currently appears in your document, including all entities, pages, and so on. You can then add any elements that are unique to your document.
To save a LayOut document as a template, follow these steps:
  1. Select File > Save As Template . The Save As Template dialog box appears.
  2. In the Template Name box, give your template a name.
  3. In the Template Folder area, navigate to the folder where you want to save your template.
  4. Click the OK button. When you create a new LayOut document by selecting File > New , you can find your template by clicking My Templates tab on the right side of the window..
  5. Click the Save button. When you create a new LayOut document by selecting File > New , you can find your template by clicking My Templates tab on the right side of the window..
