LayOut Tools
Dernière mise à jour : sept. 29, 2026•3 min lecture.
The default toolbar contains the most often used tools. To help you understand what tools are available and how to use them, take a look at the following table:
Tool
Name
What You Can Do with It
Find Out More
Select
Select entities onscreen.
Selecting Things
Line
Draw straight lines.
Drawing Lines and Shapes
Freehand
Draw lines and curves freehand.
Arc
Draw an arc based on an angle.
2 Point Arc
Draw arc endpoints and drag the arc's bulge.
3 Point Arc
Draw an arc from a pivot point.
Pie
Create a closed arc, like a slice of pie.
Rectangle
Draw a basic rectangle.
Rounded Rectangle
Create a rectangle with rounded corners.
Lozenge
Create a rectangle with extremely rounded corners.
Bulged Rectangle
Draw a rectangle with two sides that bulge out.
Circle
Draw a circle.
Ellipse
Draw an ellipse.
Polygon
Create a polygon with a specific number of sides.
Offset
Offset a line or shape.
Offsetting a Line or Shape
Fillet
Create precise rounded corners between two entities.
Drafting Tools
Chamfer
Add a 45° angle between two lines at a defined distance.
Drafting Tools
Trim
Remove excess lines and create clean intersections.
Drafting Tools
Extend
Extend lines or other entities.
Drafting Tools
Text
Add text in a bounded or unbounded text box.
Adding Text, Labels, and Dimensions
Label
Label specific items in your document.
Linear Dimension
Mark a straight dimension in the units you specify.
Angular Dimension
Mark the size of an angle.
Group
Keep related elements organized in the drawing area.
Grouping Entities
Erase
Erase an element onscreen.
Copying, Pasting, Erasing, and Other Editing Tasks
Style
Sample an element's fill and stroke settings and apply them to other elements.
Applying Styles
Split
Split lines or shapes.
Splitting and Joining Shapes
Join
Join overlapping shapes.
Start Presentation
Switch to the full-screen presentation mode.
Presenting Your LayOut Project
Add Page
Add a page to your LayOut document.
Managing and Navigating Pages
Next Page
Move to the next page.
Previous Page
Move to the previous page.
