SketchUp for Web's Expanded Toolset Last updated: 9月 29, 2026 • 2 分鐘 read.
At the bottom of the Main Toolbar, click
to open the Expanded Toolset. The Expanded Toolset contains all the tools not seen on the Main Toolbar.
When you use a tool from the Expanded Toolset, that tool appears in one of the slots at the bottom of the Main Toolbar. You can customize the Main Toolbar to add additional slots.
The Expanded Toolset contains the following tools:
Icon
Tool Name
Shortcut
Learn More
Lasso
Shift-Space
Selecting Geometry
Sample Material
Applying Colors, Photos, Materials, and Textures
Circle
C
Drawing Basic Shapes
2-Point Arc
A
Drawing Arcs
Arc
Drawing Arcs
Polygon
3-Point Arc
Drawing Arcs
Pie
Drawing Arcs
Freehand
Drawing Freehand Shapes
Rotated Rectangle
3D Text
Adding Text, Labels, and Dimensions to a Model
Offset
F
Offsetting a Line from Existing Geometry
Follow Me
Extruding with Follow Me
Flip
Flipping, Mirroring, Rotating and Arrays
Outer Shell
Modeling Complex 3D Shapes with the Solid Tools
Intersect Solid
Union Solid
Subtract Solid
Trim Solid
Split Solid
Dimension
Protractor
Measuring Angles and Distances to Model Precisely
Axes
Adjusting the Drawing Axes
Text Label
Create Section
Tag
Controlling Visibility with Tags
Zoom
Z
Viewing a Model
Zoom Extents
Ctrl/CMD+Shift+E
Viewing a Model
Zoom Window
Shift + W
Viewing a Model
Position Camera
Walking through a Model
Look Around
Walk
AI Render
SketchUp AI Render
Clicking Edit at the bottom of the Expanded Toolset allows you to customize your toolbars in the following ways:
Rearrange icons or move them between the two interfaces.
Add tools to the Main Toolbar.
Add or remove additional Recent Tool Slots.
Add or remove separators.
