Polygon Tool
Last updated: 9月 29, 2026•3 分鐘 read.
The Polygon tool ( go icon polygon.png ) adds all kinds of shapes to your model. Basic shapes often act as the foundation of a model. SketchUp draws polygon entities that have a radius and have 3 or more sides. Polygon entities act as a single line meaning they can define the edge of a face or divide a face..
In SketchUp for iPad, the Polygon tool has the following optional tool modes:
  • Increase Segments ( go icon polygon increase segments.png )/Decrease Segments ( go icon polygon decrease segments.png ) - These tool modes are a little different. Tapping one of these modes before or after you draw allows you to increase or decrease the number of line segments used to draw your circle. The number of line segments used to make up your circle appears in the Measurements box. Each time you tap the Increase Segments or Decrease Segments optional tool mode adjusts the number of line segments by one. You can also use the Measurements box to adjust the number of line segments manually.
  • Circumscribed ( go icon polygon circumscribed.png ) - In geometry, a circumscribed circle of a polygon is a circle that passes through all vertices of the polygon. You'll see a circumscribed circle appear around the outside of your polygon by default when using the Polygon tool. When this optional mode is activated, SketchUp draws polygons with a circle inside your polygon instead, with the circle passing through the midpoint of each segment.
iPad Input Methods for the Polygon Tool
After choosing the Polygon tool and activating any optional tool modes, you can use one of the iPad input methods in either Click-Move-Click or Just Draw mode to start drawing polygons.
Click-Move-Click Mode
Pencil or Multitouch - Establish the center point of your polygon using a long press. Gently moving allows you to find inferences. Long press again to finish your circle.
Mouse or Trackpad - Click the starting point and release. Move your cursor to the desired radius and click again.
Just Draw Mode
All Modes - Click or tap and hold at the starting point, then drag to your desired radius. Lift or release at the desired radius.
For more detailed guidance for using polygons and other basic shapes in your model see Drawing Basic Shapes .
