Solid Inspector in SketchUp for Web
上次更新: 10月 21, 2026•1 分鐘 閱讀。
Solid Inspector in SketchUp for Web helps you find and fix problems that prevent SketchUp from classifying geometry in your model as a solid. Making sure entities are solids can help when exporting to formats suitable for 3D printing, and is necessary when using some SketchUp tools.
Using Solid Inspector
Solid Inspector appears at the bottom of the panels on the right-hand side of the SketchUp for Web interface.
image web solid inspector
When activated, the tool asks you to select a group or component. If your selection isn’t a group or component, the tool won’t work. After selecting an entity, click Run Inspection. Solid Inspector will list any issues it finds and highlight where they are in your model in red.
image web solid issue
Solid Inspector can automatically fix the following errors:
  • Reversed faces
  • Stray edges
  • Holes in a face
Some errors can’t be fixed automatically. These errors require you to manually edit your model:
  • Border holes
  • Nested groups/components
  • Image entities
  • Short edges
Each error appears listed in the Solid Inspector panel. Selecting an error zooms to the error’s location.
