Files
Last updated: říj 21, 2026•2 min read.
The Files section provides information on where SketchUp saves files on your device and options allowing you to change or access those folders. Each category designates where a specific type of file will be saved:
Category
Type of Saved File
Models
.skp files and .skb files.
Components
Individual components or component collections.
Materials
Individual materials or material collections.
Styles
Style settings or collections.
Texture Images
Image files used to create textures.
Watermark Images
Images used for watermarks.
Export
Models exported as file types other than .skp.
Classifications
Classification systems.
Templates
SketchUp templates.
To change where SketchUp saves files, click Change File Location (icon edit materials.png) to the right of the current file path next to a category. In the file browser that appears, choose a new location for saved files. If you just want to view the folder where files are saved, click Open This Folder (icon file.jpg).
Importing and Exporting File Preferences
If you have designated specific file paths in the Files tab and want to make sure you retain those same paths in a different version of SketchUp, you can export them and then import them to that version. The easiest way to export your file preferences from one version of SketchUp to another is the Migrate Preferences tool. For detailed instructions on how it works, along with instructions on how to manually import and export preferences, see Migrating After Updating.
