Shape Types and Exporting Non-Native Elements
Not every SketchUp object should become a native Revit element. Furniture, equipment, and context are better represented in a Revit project as Families or Meshes. The four Shape Types in Revit can help you best represent the objects in your SketchUp model when importing it to Revit.
Shape type | What it represents | What it’s best for | Editable in Revit | Hosts doors and windows |
Native | A real Revit element (wall, floor, door, window, ceiling, roof, curtain wall) | Wall, slab, door, window, roof, ceiling, curtain wall | Full editing capability | Yes (walls) |
Solid Family | A loadable family with free-form solids. Facet lines show on curves. | Column, beam, casework with sharp edges | Can swap or replace | No |
Mesh | A loose mesh in the project (DirectShape). Not a family. | Heavy context and entourage | No | No |
Mesh Family | A family that holds one mesh. No facet lines. | Chair, table, lamp, curved object, trees, people, cars, terrain, site context, stairs and railings | Can swap or replace | No |
With every Shape Type, the following properties of your objects won’t change:
Geometry is present with its true shape.
Category follows your choice in Select Objects (or the IFC class).
Materials come from SketchUp.
The element can be scheduled, tagged, and filtered by category.
Native Elements
Native elements are built from the plan, have the thickness and height of your solids, and are editable like any Revit element. They follow rules about solids, face orientation, and thickness.
Families
Families are loaded into the project and placed as instances. Each family has the following properties:
Component reuse – Identical component instances share one family. Fifty chairs make one family and fifty instances. Fifty separate groups make fifty families.
Naming – The family name is the component name.
Level of detail – A family with more than the Max shapes per family setting is split into parts with a default of 75.
Parts and materials – Each solid shape has its own material parameter, Part_1_Material, Part_2_Material, and so on, allowing you to remap each one.
Tags – Each tag is converted into a subcategory within Object Styles.
Nesting – Child components are nested families. Containers, such as IfcSite, IfcBuilding and IfcBuildingStorey, are not nested. Their children import flat.
Meshes
A Mesh is the lightest option. It is one loose object in the project. Meshes have the following properties:
Family – None
Level – None
Type Swap – Cannot be done
Materials – As set in SketchUp
Solid and Mesh Families
Solid and Mesh Families support the following properties:
View the Family in 3D and in plans
Override visibility by category
Tagging and scheduling
(Solid Families only) Remap material
Solid and Mesh Families do not support the following properties:
Parametric editing
Can host doors or windows
Can join with walls or floors
Object Category Mapping
Each object's category comes from its IFC class. Common categories include:
IFC Class | Revit Category |
IfcColumn | Columns |
IfcBeam, IfcMember | Structural Framing |
IfcFooting, IfcPile | Structural Foundations |
IfcFurniture, IfcFurnishingElement | Furniture |
IfcLightFixture | Lighting Fixtures |
IfcSanitaryTerminal | Plumbing Fixtures |
IfcFan, IfcPump, IfcChiller and other plant | Mechanical Equipment |
IfcElectricGenerator, IfcElectricMotor | Electrical Equipment |
IfcStair, IfcRailing, IfcRamp | Generic Model |
Unclassified | Generic Model |
When Revit refuses a category for a family, the object goes to Generic Models.
