Applying Materials
Last updated: zář 29, 2026•2 min read.
Applying materials to your model is simple:
  1. (Optional) You can pre-select the faces and edges you want to apply the material to.
  2. Open the Materials panel or activate the Paint Bucket ( icon paint bucket.png ) tool. The default shortcut is B for Bucket!
  3. On the Select tab, browse and select a material.
  4. If you pre-selected faces or edges, SketchUp will apply the material to your selection.
  5. If you didn’t pre-select anything, click the face or edge you want to apply that material to.
  6. SketchUp applies the material to your selection.
To restore a face to the default colors, use the Default option listed at the top of the in-model library.
You can also apply materials to a group or component. Pre-select multiple objects, or click one object at a time to paint it or to any geometry within a group.
