Exporting SketchUp Tags to Revit
Last updated: lis 16, 2026•2 min read.
Tags are used in SketchUp to organize a model. In Revit, any imported object retains the tag it had in SketchUp. Untagged geometry retains “Layer0” as its tag name in Revit and appears as Untagged in the Select Objects dialog.
Tags for objects imported as Families become Revit subcategories. These subcategories are nested under the Revit category for that object. The following examples show how tagged objects imported as families appear in Revit.
SketchUp
Object Category
Revit Subcategory
Structural
Structural Framing
Structural Framing > Structural
Exterior Skin
Generic Models
Generic Models > Exterior Skin
Furniture
Furniture
Furniture > Furniture
MEP Rough-In
Mechanical Equipment
Mechanical Equipment > MEP Rough-In
Tags do not become subcategories when imported as Revit system elements like walls, floors, and roofs.
Controlling Visibility
Revit’s subcategories provide visibility tools for SketchUp geometry. You can use them in the following ways:
  • To show or hide a tag, use Visibility/Graphics Overrides, open the category, then clear or select the subcategory.
  • To change line weight, color, or pattern, use the same Visibility/Graphics Overrides for each view.
  • To reuse a setup, save your settings in a View Template.
  • To isolate a system, hide every other subcategory so only one is visible.
  • To set project-wide styles, click Manage > Object Styles, open the category tab, and edit the imported subcategories.
Worksets
Revit Worksets control collaboration. SketchUp tags do not become worksets and are not the same as worksets.
Tag Best Practices
When you create tags in your SketchUp model you intend to export to Revit, there are a few best practices to keep in mind:
  • Use meaningful naming conventions for your tags.
  • Tag entire objects, not just faces. Tags on loose faces can make extra unnecessary subcategories.
  • Keep your list short. Every tag becomes a subcategory in every Revit category that uses it.
  • Classifications should be used along with tags. Classes define the category, and tags define the subcategories.
  • Audit your tags before importing by removing stray or duplicate tags.
