Dialog Boxes and Trays
Last updated: říj 21, 2026•2 min read.
Sketchup organizes available features into dialogs, also known as panels. Each panel provides easy access to SketchUp features and broader functionality while modeling.
Available Panels
The following panels are available:
  • Entity Info
  • Materials
  • Components
  • Styles
  • Tags
  • Scenes
  • Shadows
  • Fog
  • Match Photo
  • Soften Edges
  • Overlays
  • Instructor
  • Outliner
image sketchup dialog boxes trays
SketchUp provides a default tray with pre-selected panels. The default tray appears on the right side of the modeling window by default. You can dock each available tray on either the left or right side of the interface.
image sketchup tray position
To change the position of a tray, click and drag the tray’s title bar. You can use the references that appear on the screen to dock it on either side of the interface, or leave it as a free floating window.
image sketchup tray floating
If you’ve added additional trays, each tray appears as a tab at the bottom of where you docked it. The title bar of each tray contains an option to close the tray. If you’ve docked the tray, you can pin it so that it’s always visible.
To further customize your trays, click Window > Manage Trays.
image manage tray dialog
In Manage Trays, you can:
  • Change which panels appear in each tray
  • Create new trays
  • Rename a tray
  • Delete a tray
