Using the SketchUp Importer for Revit
最后更新时间: 11月 16, 2026•4 分钟 阅读。
The SketchUp Importer for Revit can help you download SketchUp (.skp) or TrimBIM (.trb) files saved locally on your device, those you’ve saved to Trimble Connect, and models available on 3D Warehouse.
After installing the extension, the SketchUp ribbon is available and docked in the Revit interface. You can use the panel to import files or inspect and edit what you’ve imported. The panel contains three trays:
  • Entity Info – This tray contains information about a selected imported element and provides options to change common properties. The tools on the tray provide additional options to manipulate the elements in your project.
  • Outliner – A searchable tree of the elements in your project. The tools on the tray can help you control visibility of imported elements. You can also organize elements by Source—elements from SketchUp or originals from Revit—and Revit levels, categories and phasing.
  • Materials – A list of materials in the imported elements. For more information, see Exporting Materials to Revit.
Import Options
Importing a Locally Saved File
To import a locally saved .skp or .trb file into a Revit project, follow these steps:
  1. In Revit, open your project file.
  2. On the SketchUp ribbon, click SketchUp > Import > Local.
  3. Select a .skp or .trb file.
  4. Review object classifications in the Select Objects To Import dialog. For more information on all the options available in the dialog, see Selecting Objects to Import to Revit.
  5. Click Import. The importer applies your saved import settings and the Importing TrimBIM File dialog appears. For more details, see Trimble SketchUp Importer for Revit Settings.
  6. Monitor progress through theImporting TrimBIM File dialog, which  contains the following information:
    • Importing Model <File Name> – Name of the file being imported
    • Objects and Planes – Size of the import
    • Now Processing – Shows each step of the import process
    • Step, Percent, and Time – Current step of processing, completion percentage, and total elapsed time.
  7. Click Cancel at any time to abort the import process.
Importing from Trimble Connect
The Trimble Connect panel is separate from the SketchUp Importer for Revit panel. To import a file saved to Trimble Connect into a Revit project, follow these steps:
  2. On the Trimble Connect panel, click SketchUp > Import > Trimble Connect. The Trimble Connect dialog will open.
  3. In Trimble Connect, navigate to and double-click the file you want to import. The download dialog with a progress bar will appear along with the Select Objects to Import dialog.
  4. Review object classifications in the Select Objects To Import dialog. For more information on the options available in the dialog, see Selecting Objects to Import to Revit.
  5. Click Import. The importer applies your saved import settings and the Importing TrimBIM File dialog appears. For more details on all settings and how to adjust them, see Trimble SketchUp Importer for Revit Settings.
  6. Monitor progress through the Importing TrimBIM File dialog, which  contains the following information:
Importing from 3D Warehouse
The Trimble Connect panel is separate from the SketchUp Importer for Revit Panel and is where you will initiate imports from 3D Warehouse. To import a file saved to 3D Warehouse into a Revit project, follow these steps:
  2. On the Trimble Connect panel click SketchUp > Import > 3D Warehouse. A 3D Warehouse window will open.
  3. Search for a model you want to import.
  4. On the model’s details page, click Download. The download dialog with a progress bar will appear along with the Select Objects to Import dialog.
  5. Review object classifications in the Select Objects To Import dialog. For more information on the options available in that dialog, see Selecting Objects to Import to Revit.
  6. Click Import. The importer applies your saved import settings and the Importing TrimBIM File dialog appears. For more details on all settings and how to adjust them, see Trimble SketchUp Importer for Revit Settings.
  7. Monitor progress through the Importing TrimBIM File dialog, which  contains the following information:
  8. Click Cancel at any time to abort the import process.
  9. Once conversion finishes, select the location in your project where the object should be placed.
Import Results
Success or failure messages may include notations about your import. For example, you may get a notice that some objects were imported in a different category than what you designated or that geometry was simplified.
After the import process completes, you’ll see one of the following messages:
Title
Message
Import Completed
<file> imported successfully! (<time>)
Import Cancelled
Elements imported before cancelling were kept.
Import Failed
<file> could not be imported.
Import Error
An error occurred during import.
(none)
Open a Revit document before importing.
(none)
Could not resolve import settings.
(none)
No curtain wall types were found in this project.
(none)
No levels were found in this project.
When an import fails, one of the following reasons will appear:
Reason
Cause
Next Steps
Revit could not modify the document (it was read-only or temporarily disabled during import)...
The project is read-only, or Revit is in an edit mode.
Finish any active edits in Revit, make sure the file is not read-only, and reopen the project and import again.
An imported element name conflicts with existing content in the document.
A family or type name already exists.
Rename the component in SketchUp and import again.
Revit rejected part of the geometry during import. Check the log for details.
Revit refused some geometry.
Open the log and find the failed object. Make adjustments as needed.
The file appears to be invalid or corrupted and could not be read.
The .trb is damaged.
Save the file again and re-attempt the import.
Template files are missing...
Family templates are missing from the installation.
Re-install the extension.
The import took too long and was stopped.
A time-out.
Import fewer objects, or use Mesh for dense context
The file could not be found.
The file was moved or deleted.
Re-attempt the import.
The SketchUp conversion components are missing...
Converter files did not load.
The geometry of these objects could not be built: 'A', 'B'... and N more.
Named objects failed (up to five are named).
Locate the objects in your SketchUp model and make adjustments as needed.
The category of these objects could not be assigned: ...
Revit refused the category.
Choose another category in Select Objects.
The notices you may receive after importing are:
Notice
Cause
What to do
Some geometry was simplified due to boundary issues in the SketchUp model.
Faces were removed (not planar, self-intersecting, too small), holes were filled.
Clean the objects, then import again.
**roof object(s) could not be built as editable Revit roofs and were imported as meshes in the Roofs category.**
The roof failed a shape check.
Simplify the roof to one closed slab of even thickness with no duplicate faces and consistent face orientation. See the Modeling Playbook
**curtain wall(s) could not be built as native Revit curtain walls and were imported as generic objects instead.**
The parts do not form a regular grid, or Revit aborted the process.
Use a regular grid, or draw the wall as surfaces and thin solids. See the Modeling Playbook
**object(s) were imported as Generic Models because Revit does not allow for families.**
A system category was chosen for a family.
Choose another category, or Native or Mesh
For additional error messages and how to address them, see Troubleshooting the SketchUp Importer for Revit.
