Troubleshooting the SketchUp Importer for Revit
最后更新时间: 11月 16, 2026•1 分钟 阅读。
The following sections can help if you encounter issues using the SketchUp Importer for Revit.
Error Messages Before Import
Message
What to do
Could not generate a preview for this model.
Save the file in SketchUp again and retry.
Could not convert the SketchUp file. Check the log for details.
Check the log.
Could not save the converted file. Check available disk space and permissions.
Free disk space, check Temp permissions.
Invalid or unsupported TrimBIM file.
Save the file again.
Viewer viewport could not be created.
Update your graphics driver and restart Revit.
**Preview failed: **
Send the log to support.
Please check at least 1 object from the list to import
Check at least one object.
Import Failure Messages
Reason Shown
Cause
What to do
Revit could not modify the document (it was read-only or temporarily disabled during import)...
The project is read-only, or Revit is in an edit mode.
1. Finish any edit. 2. Make sure the file is not read-only. 3. Reopen the project and import again.
An imported element name conflicts with existing content in the document.
A family or type name already exists.
1. Rename the component in SketchUp. 2. Import again
Revit rejected part of the geometry during import. Check the log for details.
Revit refused some geometry.
1. Open the log. 2. Find the object. 3. Fix its solid, or set it to Mesh.
The file appears to be invalid or corrupted and could not be read.
The .trb is damaged
1. Save the .skp again. 2. Import again.
Template files are missing...
Family templates are missing from the installation.
Run the installer again.
The import took too long and was stopped.
A time-out
Import fewer objects, or use Mesh for dense context.
The file could not be found.
The file was moved or deleted.
Select the file again.
The SketchUp conversion components are missing...
Converter files did not load.
The geometry of these objects could not be built: 'A', 'B'... and N more.
Named objects failed (up to five).
1. Find the named objects in SketchUp. 2. Run Solid Inspector. 3. Import again, or set them to Mesh.
The category of these objects could not be assigned: ...
Revit refused the category.
Choose another category in Select Objects.
Notices
Notice
Cause
What to do
Some geometry was simplified due to boundary issues in the SketchUp model.
Faces were removed (not planar, self-intersecting, too small), holes were filled.
Clean the objects, then import again.
**roof object(s) could not be built as editable Revit roofs and were imported as meshes in the Roofs category.**
The roof failed a shape check.
Simplify the roof to one closed slab of even thickness with no duplicate faces and consistent face orientation. See the Modeling Playbook.
**curtain wall(s) could not be built as native Revit curtain walls and were imported as generic objects instead.**
The parts do not form a regular grid, or Revit refused.
Use a regular grid, or draw the wall as surfaces and thin solids. See the Modeling Playbook.
**object(s) were imported as Generic Models because Revit does not allow for families.**
A system category was chosen for a family
Choose another category, or Native or Mesh
Model Issues Post-Import
What you see
Likely cause
What to do
A window or door has no opening in the wall
The window or door was unhosted: no overlap, no native wall, set to Mesh, or on a curved wall.
Overlap the wall or door onto the wall by at least 10 mm, keep the wall Native.
A wall became a generic family
It was not a closed solid.
Check Volume and fix the solid.
A floor is missing or empty
No horizontal face, or too many faces.
Add a flat top face, or raise Max faces per floor.
Everything sits on one Level
Import level is a single Level.
Choose By elevation and create Levels first.
A mesh has no Level
Meshes cannot have a Level.
Choose Native, Solid Family, or Mesh Family.
A material looks wrong
A Revit material with the same name already exists
Rename it in SketchUp, or use Map Materials (not for meshes).
A finish is on the wrong side
Face orientation
Reverse the faces.
Many tiny families
Many separate groups
Turn repeated groups into components.
Nothing changed on a second import
Elements from the earlier import are skipped
Delete the old elements first.
A window sill height is wrong
No Sill Height property
Add the property. A number is millimeters.
Guides, text or an image are missing
The guides, text, or image  was not imported.
The guides, text, or image are dropped without a warning. Redraw them in Revit.
An unexpected Generic Model appeared
A SketchUp dimension, or loose geometry
Delete dimensions and loose geometry before importing.
Checking Logs
The SketchUp Importer for Revit logs every attempt to import a file, even if the import fails or is interrupted. Reviewing these logs can help determine why there was an issue with your import.
To access your logs, selectInfo > Log folder in the extension. You can also find the logs in a .log file in the following locations:
File
Location
Current log
%LOCALAPPDATA%\Trimble SketchUp for Revit\RevitExporter.log
Older logs
RevitExporter_old_<date and time>.log in the same folder. The ten newest are kept, and the log rolls over at 10 MB.
The ten most recent events are in the RevitExporter.log file. Older events appear in the same folder with a date and time added to them.
The logs provide the following information:
Prefix
What it tells you
[IMPORT]
One summary line: Outcome, elements, failures, duration, fallbacks, holes
[SETTINGS]
The settings used
[REVIT-WARNINGS]
Revit warnings that were Hidden, counted by kind
[AUDIT]
Door and window outcomes: Hosted, freeform, skipped, lost
[HOST]
One line per door or window: The host wall and the reason if it was not hosted
[SILL]
Where a window's sill height came from
[WALL], [WALL-TYPE], [WALL-FALLBACK]
Wall events and fallbacks
[CURVED-WALL]
Curved wall results
[FLOOR], [FLOOR-TYPE]
Floor events
[CURTAIN]
Curtain wall results
[ROOF]
Roof results and rejection reasons
[Level]
Level assignment issues
[TEXTURE]
Texture handling
Other files you may need include:
Item
Location
Import and panel settings
%LOCALAPPDATA%\Temp\Trimble SketchUp for Revit\
Texture store
%LOCALAPPDATA%\Trimble SketchUp for Revit\Textures
Temporary downloads
%TEMP%\TrimbleSketchUpRevit\ and %TEMP%\Trimble SketchUp for Revit\WarehouseDownloads\ (cleaned up after each import)
Contacting Support
You can contact support through Info > Contact support from the extension or https://my.trimble.com/s/contactsupport. When contacting support, provide the following information:
  1. Your latest log files.
  2. The file you are trying to import.
  3. The Revit and SketchUp versions you use.
  4. A detailed description of the issue.
