Conversion Failed
最后更新时间: 8月 21, 2026•1 分钟 阅读。
Conversion Failed.
The is the catch-all error shown when an import fails without a specific reason found. In the dialog you see after the attempted import, check the Last Error Description field for more details. If you can't find a root cause, check the following:
Open the file in Revit, create and save a new 3D view, and retry the import.
Check that you have the proper permissions to the destination folder.
Verify you have enough disk space to save the file.
