Selecting Objects to Import to Revit
最后更新时间: 11月 16, 2026•2 分钟 阅读。
During the import process, the Select Objects to Import dialog lets you preview your model, choose which objects to bring in, and decide how each one is imported.
image sketchup to revit select objects window
Preview Colors
You can color the preview by selecting Materials or IFC Class above the preview window. If you choose Materials, the importer will use the materials present in the SketchUp model to color each object. If you choose IFC Class, each class will use a unique color. These options can help you spot misclassified objects quickly.
Sorting Options
You can sort the list by IFC Class or by Tags. IFC is the default sorting method. Any changes to selected objects are retained if you switch how the list is sorted. Unclassified objects appear under UNCLASSIFIED, and untagged objects under Untagged.
Revit Category
The category indicates where the object belongs in Revit. The category originates from the object's IFC class:
IFC Class
Default Category
IfcWall, IfcWallStandardCase, IfcCurtainWall
Walls
IfcSlab, IfcFloor
Floors
IfcDoor, IfcWindow
Doors, Windows
IfcRoof
Roofs
IfcCovering marked as a ceiling
Ceilings
IfcFurniture and similar
Furniture
IfcColumn
Columns
IfcBeam, IfcMember
Structural Framing
Everything else
The class's mapped category, or Generic Model
More classes and their categories are listed in Importing Shape Types and Non-Native Elements.
You can change the category of any object. The available options are:
  • Casework
  • Ceilings
  • Columns
  • Doors
  • Entourage
  • Floors
  • Furniture
  • Generic Model
  • Lighting Fixtures
  • Mechanical Equipment
  • Planting
  • Plumbing Fixtures
  • Railings
  • Roofs
  • Site
  • Specialty Equipment
  • Stairs
  • Structural Foundations
  • Structural Framing
  • Walls
  • Windows
Shape Type
The shape type determines how the object is built.
Shape Type
Result
Allowed For
Native
A real Revit element
Walls, Floors, Doors, Windows, Ceilings, Roofs and Curtain Walls
Solid Family
A loadable family with solids
Every category except Walls, Floors, Roofs, Ceilings, Stairs and Railings
Mesh
A loose mesh in the project
Every category
Mesh Family
A family holding one mesh
For more information, see Importing Shape Types and Non-Native Elements.
The footer shows information on how many objects are selected, the Plane count of those objects, and the progress of your import. The Plane count measures how many faces are in the objects you selected. The progress will show an estimate based on this face count.
