Troubleshooting a Corrupted File
最后更新时间: 8月 21, 2026•3 分钟 阅读。
A corrupted file is a file that contains one or more errors preventing SketchUp from opening it as normal. A file can become corrupted due to issues during the save process, or sending an uncompressed file to another person. If you attempt to open a SketchUp file and receive one of the following error messages, that may mean the file is corrupted:
  • Unexpected File Format
  • File Not Found
  • File Invalid
  • Failed to Open Document
Corrupted files will not open in SketchUp. When this happens, the only way you can continue working is if you have a backup file.
By default, SketchUp creates a backup of all your saved files by default. If you aren’t sure if SketchUp is creating backups, you can check by following these steps:
  1. In the title bar, click Window.
  2. Select Preferences from the dropdown menu.
  3. Click General.
  4. Ensure the checkbox next to Create Backup is selected. If it is not, click the checkbox to enable it.
When Create Backup is selected, Sketchup will automatically create a backup file.
Image of General tab of Preferences with arrow pointing to Create backup
These backups are usually located in the same folder as the original file. On Windows, backups appear with the .skb extension instead of .skp. On MacOS, the file name appears with ~ appended to the end.
There are a few best practices you can follow to help make sure you won’t end up with a corrupted file:
  1. Save your files to Trimble Connect. For more information on how SketchUp and Trimble Connect work together, see Trimble Connect.
  2. Save your files locally. Avoid using other cloud services like OneDrive, Dropbox, or Google Drive. To make sure your files are saving locally, check where your files are saved in the Files tab of Preferences. For more information, see Files and General.
  3. If you need to use a cloud service, turn automatic syncing off.
  4. When sending a file to someone else, compress into a separate .zip file to make sure the file can’t be altered during the transfer.
