iPad Expanded Toolset
Last updated: lis 10, 2026•2 min read.
The three ellipses icon (icon ellipsis horizontal) appears at the bottom of the Main Toolbar. Choosing that icon opens the Expanded Toolset, which contains the rest of your tools.
The Expanded Toolset contains the following:
Icon
Optional Tool Modes
Tool Name
Learn More
Select
Select Tool
N/A
Markup
Markup Tool
N/A
Insert Image
N/A
go icon inference lock red.png go icon inference lock green.png go icon inference lock blue.png
Freehand
Freehand Tool
go icon inference lock red.png go icon inference lock green.png go icon inference lock blue.png go icon inference perpendicular.png go icon inference parallel.png
2 Point Arc
2-Point Arc Tool
Arc
Arc Tool
Polygon
Polygon Tool
3 Point Arc
3-Point Arc Tool
Pie
Arc Tool
Rotated Rectangle
Rotated Rectangle
go icon 3d text
N/A
3D Text
3D Text
N/A
Offset
Offset Tool
N/A
Follow Me
Follow Me Tool
Tag
Tag Tool
Flip
Flip Tool
N/A
Outer Shell
Outer Shell Tool
N/A
Intersect
Intersect Tool
N/A
Union
Union Tool
N/A
Subtract
Subtract Tool
N/A
Trim
Trim Tool
N/A
Split
Split Tool
icon create guide points
icon create guide lines
Tape Measure
Tape Measure Tool
N/A
Dimension
N/A
N/A
Protractor
Protractor Tool
Axes
N/A
N/A
Text Label
N/A
Create Section
N/A
go icon orbit suspend gravity
Orbit
N/A
N/A
Pan
N/A
N/A
Zoom
N/A
N/A
Zoom Extents
N/A
N/A
Position Camera
N/A
N/A
Look Around
N/A
N/A
Walk
N/A
N/A
View in AR
N/A
N/A
Scan-to-CAD
N/A
N/A
Present
Presentation Mode
Optional Tool Modes
Many tools have optional tool modes. Optional tool modes modify the way you use a tool. If a tool has optional tool modes, an icon for each available mode will appear. For example, the Lasso tool has three optional modes: Add, Remove, and Inverse.
The icons representing the optional tool modes available for each tool are listed in the above table.
