Installing V-Ray for SketchUp
Senast uppdateras: nov. 16, 2026•2 min upplästa.
Before installing V-Ray for SketchUp, confirm you meet the following system requirements:
Processor
Intel* 64, AMD64 or compatible processor with AVX2 support
RAM
Minimum 8 GB RAM, recommended 16 GB RAM
Hard Disk Space
minimum 2GB, recommended 12GB (includes additional downloadable content)
TCP/IP
Only IPv4 is supported. IPv6 is currently not supported
Operating System
Windows 10, Windows 11
SketchUp
Current Supported Versions
GPU Support
NVIDIA GPUs of Maxwell generation or later with the latest recommended video driver (for both CUDA and RTX - enabled cards). V-Ray Vision requires a Graphics card with DirectX 11 or DirectX 12 and Shader Model 5.0 capabilities.
Users with a SketchUp Studio subscription can choose to download V-Ray for SketchUp along with other Studio entitlements in the Windows Installer.
If you have already installed SketchUp, you can install V-Ray for SketchUp by following these steps:
  1. Download the V-Ray for SketchUp installer, available in your My Products page. Account Management Portal .
  2. After the download completes, locate the installer and double-click to launch.
  3. Please review the license agreement and click Next for your installation options.
  4. When prompted, select the version of SketchUp you are using.
  5. Select Install to use the default installation options.
  6. Select Advanced to specify if you want to install Chaos Swarm and licensing options. V-Ray for SketchUp requires the Local option for licensing.
  7. After installation you'll see options to open the release notes file or share anonymous data with Chaos Group.
  8. Click Done to close the installer.
