Exporting Materials to Revit
Senast uppdateras: nov. 16, 2026•3 min upplästa.
When you import a SketchUp file into Revit, Revit converts them to Revit materials. The conversion happens in three stages:
  1. Extract – The converter reads each SketchUp material for color, transparency, roughness, metalness, texture, and orientation.
  2. Create or Match – The importer creates a new Revit material, or finds an existing one with the same name.
  3. Assign – The importer applies materials to native elements as layer or parameter materials and to families as Part_N_Material parameters.
Matching Materials
If a Revit material has the same name as the imported SketchUp material, the importer uses the Revit material. The importer will attempt to find a matching name in Revit and the search is not case-sensitive. If a matching name is found, the properties of the existing Revit material are used. To help make sure your materials appear as intended:
  • Make sure any SketchUp materials and Revit template that share the same qualities also have the same name.
  • Use unique names for your SketchUp materials.
New Materials
When the importer can’t identify a matching Revit material, one will be made with the following properties:
  • The appropriate SketchUp color and transparency.
  • A name of <name> Appearance based on Revit’s Generic asset. Named materials will use the same name. Revit does not allow some special characters. Unnamed textures and colors will use a code instead.
  • Faces without materials will have the SketchUp Default texture assigned to them. This ensures their default texture remains separate from the Default material in your template.
  • The Use Render Appearance option enabled.
For textures, the importer will also perform the following actions:
  • The importer places the texture image in the material’s diffuse slot with its real-world size and offset from SketchUp. Transparent images also get a cut-out map.
  • Textures save as .png files in the extension’s file system. These file paths are assigned to each material and files should not be moved to another location.
  • In Revit’s Settings, the texture storage limit caps the size of textures. The default cap is 2GB. If you reach that limit, the oldest textures are removed from the project. Removed textures won’t appear unless you import the model again.
  • Roughness is changed to Glossiness in Revit, set to one level lower than in SketchUp.
  • Metalness turns on Metal in Revit for that material.
  • Materials without a texture only get color and transparency.
The Materials Tray
The SketchUp Importer for Revit extension’s SketchUp panel contains a Materials tray that includes options for manipulating the materials you’ve imported with your SketchUp model. In the Materials tray, you can:
  • Search for materials
  • See what materials are in use
  • Refresh your materials to reload the list
  • Preview a material
  • Map materials
The Map Materials function helps you swap the material on an object you’ve selected. To swap a material:
  1. Select the object you want to swap the material for.
  2. In the Materials tray, click the swatch for the material you want to replace. The Map Materials dialog will appear.
  3. In Map Materials, review the rows of objects and the material information in each column of the row. The row label also shows where that material appears in relation to the rest of your project.
  4. Select one or more rows you would like to change the material for.
  5. Choose a new material, or choose No Material to clear the clot.
  6. Choose Instance or Type under Parameter Type. System Families can only select Type. Family parts can select either. Built-in family parameters can only select Type.
  7. Click Apply.
  8. To abort the operation, click Cancel.
