Using the Measurements Box
Senast uppdateras: sep. 29, 2026•2 min upplästa.
The Measurements Box appears in the lower right corner of the SketchUp interface. The way the Measurements Box works changes based on which tool you are using:
  • When you create geometry, you can enter a value in the box and specify precise dimensions.
  • When moving or rotating, you can enter a value to help you position your geometry.
  • When scaling geometry, entering a value helps you scale to a precise value.
For any tool, you can change the type of unit of measurement by specifying the new unit type when typing in a value.
Unit
How to Specify It
Example
Inches
number + “
10”
Feet
number + ’
10’
Millimeters
number + mm
10mm
Centimeters
number + cm
10cm
Meters
number + m
10m
The Flip and Move tools can help you create multiple copies of an entity in a pattern, also known as an array. You can use the Measurements Box to specify how that array appears.
Array Type
How to Specify It
Example
Spacing
External
number + x
3x
Equal distance as original and initial copy
External
number + *
3*
Internal
number + /
3/
Equal distance between original and initial copy
