Create Your Own Materials
Senast uppdateras: nov. 10, 2026•2 min upplästa.
SketchUp’s material libraries offer a variety of useful materials that you can add to your models. To meet your design intent, you may need to create materials using 2D image files as a starting point.
Windows
To create a new material from your own files or color codes open the Materials panel and follow these steps:
  1. On the Select tab, click Create New Material ( icon add tag.png ). The Create Material dialog will open. desktop materials create material panel.png
  2. Type a name for the new material in the text field.
  3. Use the color wheel to choose a color.
  4. To use an image add, select Use Texture Image .
  5. In the File Explorer window that appears locate and select an image file.
  6. Adjust the texture size and opacity. If you have corresponding texture maps for your image texture, you can add and adjust them here.
  7. Click OK . Your new material will appear selected in the In Model collection.
