No Valid 3D View Found in Revit File
Senast uppdateras: aug. 21, 2026•1 min upplästa.
No valid 3D view can be found in the Revit file.
If the imported file contains no 3D views, or if the views it does contain aren’t accessible by the importer, this message will appear. In order to successfully import the file you'll need to create a 3D view in Revit, save your file, and attempt the import again.
