Using Scan Essentials
Senast uppdateras: aug. 21, 2026•5 min upplästa.
The Scan Essentials toolbar contains everything you need to start using point cloud data in your SketchUp models.
You can assign keyboard shortcuts to any of the features in the Scan Essentials toolbar, just like you can with other SketchUp tools. For more information see Shortcuts . To toggle the Scan Essentials toolbar on and off, select View > Toolbars .
Each section of the toolbar contains a group of similar tools.
Loading & Unloading a Point Cloud
To load a point cloud file into a SketchUp modeling session, use the File Open button ( Extending Scan Using3.png ). Supported point cloud file types are:
  • RWP
  • TZF
  • e57
  • LAS/LAZ
  • PLY
Multiple point clouds files can be loaded into SketchUp by selecting multiple files at once. The point clouds must be aligned with each other before importing into SketchUp. The point cloud used in SketchUp is session based only. The actual points will not be saved within the SketchUp model SKP file. A reference to the original point cloud file will be preserved in the SketchUp file for the purpose of reloading the point cloud in subsequent sessions.
With the Point Cloud Manager ( Extending Scan Using4.png ) you can manage the point cloud data you have added to your model.
To unload a point cloud from the SketchUp modeling session, us the Unload button ( Extending Scan Using6.png ). This action removes the point cloud from the SketchUp session.
Point Cloud Blending
You can set the point cloud visibility and how much your point cloud is blended with your model’s geometry using the following Blending options:
  • 0% Blending ( icon 0 opacity ) – Point cloud visibility is 0%.
  • 50% Blending ( icon 50 opacity ) – Point cloud visibility is 50%.
  • 75% Blending ( icon 75 opacity ) – Point cloud visibility is 75%.
  • 100% Blending ( icon 100 opacity ) – Point cloud visibility is 100% (fully visible).
  • Conditional Blending with Half Resolution ( Extending Scan Using12.png ) - Halves the points displayed around your model's geometry.
  • Conditional Blending with Transparency ( Extending Scan Using13.png ) – Applies 50% visibility to points that are close to SketchUp entities.
Point Cloud Interaction
Each interaction mode sets different prioritization levels when interacting with SketchUp geometry and the points in the point cloud.
With Disable Point Cloud Snapping ( icon disable snapping ) you can only detect and interact with native SketchUp entities that are in close proximity with points in a point cloud.
When active, Point Cloud Pick ( icon snap to point cloud ) prioritizes snapping to points in a point cloud over native SketchUp entities.
SketchUp Pick ( icon snap to sketchup ) prioritizes interactions with SketchUp entities over points in the point cloud. This can be useful when attempting to snap to SketchUp geometry positioned behind the elements of a point cloud.
Guide Creation Tools
With Scan Essentials guide creation tools you can mark specific points and measure the distances between points in a point cloud. You can then use these points as a reference.
You can place a point using the Guide Point tool ( Extending Scan Using20.png ). With the Guideline tool ( Extending Scan Using21.png ) you can set a guideline between two points on a point cloud.
Clipping Box Tools
The Clipping Box tools present a few ways you can control how much of the point cloud you see in your modeling environment by creating a Clipping Box. A Clipping Box isolates specific areas of the point cloud. Create and edit Clipping Boxes with the following tools:
  • Reset Clipping Box Transformation ( Extending Scan Using23.png ) – Reset dimensions, position, and orientation of the active Clipping Box.
  • Deactivate Clipping Box ( Extending Scan Using24.png ) – Deactivate the active Clipping Box.
  • Create Clipping Box from Point Cloud ( Extending Scan Using25.png ) – Create a Clipping Box from the point cloud.
  • Create Clipping Box from current SketchUp selection ( Extending Scan Using26.png ) – Create a Clipping Box around the currently selected SketchUp geometry.
  • Create Clipping Box from Cloud Selection ( Extending Scan Using27.png ) – Create a Clipping Box around the currently selected point cloud.
Adjusting the Point Cloud Position
There are two methods you can use to adjust the position of a point cloud in SketchUp:
  • Move Point Cloud ( Extending Scan Using29.png ) – When activated, you can move the position of your point cloud to anywhere with the modeling window.
  • Rotate Point Cloud ( Extending Scan Using31.png ) – Rotate your point cloud around a specific point.
Ground Mesh Tools
With the Ground Mesh tools you can turn a ground terrain point cloud into an accurate, quad-faced terrain mesh, adding context to your model. The Ground Mesh tools can extract ground information from a full point cloud or from an already segmented or classified cloud. When you select Create Ground Mesh ( Extending Scan Using34.png ) there are three methods you can use to add ground mesh to your model:
  • Fit Cloud - Create a mesh over existing ground data and fill in any holes.
  • Rectangular - Create a mesh in a rectangular area.
  • Bounded - Use a face in your SketchUp model to create a mesh in a specific area.
If you have already created ground mesh you can Add Detail ( Extending Scan Using39.png ) to increase the resolution of the selected faces in your ground mesh. You can also use Make Solid ( Extending Scan Using40.png ) to turn the mesh into a SketchUp solid.
