Version of Revit File Not Supported
Последнее обновление: авг. 21, 2026•1 мин чтения.
The version of the Revit file is not supported.
If your .rvt file was saved with a version of Revit that is older than 2011 or not yet supported by the Revit Importer, this message will appear. If it's older than 2011, you'll need to save the file on a newer Revit version. If you are using the latest version of Revit and you see this message, try using IFC or other file formats to import it. For more information, see Revit Version Compatibility.
