Importing Models, Components, and Images
Last updated: окт. 8, 2026•1 мин read.
With the Import option, available in the dropdown found in the Main Menu, you can import other 3D models of the following types into your SketchUp model:
.skp
.3ds
.dae
.dem
.dwg
.dxf
.kmz
.stl
When you attempt to import a 3D file you will be prompted to download it as a component. Once imported you can edit or change it just like you would any other component.
You can also import the following 2D file types:
.dwg
.dxf
.jpg
.png
When you attempt to import a 2D file you will be prompted to save it as an image or a material.
