Crash Messages in SketchUp
최종 업데이트: 8월 21, 2026•2 분 읽음.
When SketchUp crashes there are a few things to take a look at that may help:
  • System settings or compatibility issues
  • An error in your SketchUp installation or an extension
  • A problem with a model’s file or a plugin
  • Outdated graphics drivers or graphics hardware
To help troubleshoot these issues, we’ve listed a few examples and some tips to help you get things up and running again.
Category
Issue
Potential Solution(s)
System Requirements & Compatibility
Hardware Requirements Not Met
Check SketchUp's minimum system requirements and make sure your system meets each category, especially RAM and graphics card capabilities.
Incompatible Operating System
Supported versions of SketchUp are only approved for use with certain operating systems. Make sure the one you are using is compatible .
Temporary Glitches
Reboot your computer.
Graphics Cards and Software
Outdated or Corrupted Drivers
Review the information in Graphics and Performance and make sure your hardware and software is up to date.
Graphics Engine Errors
Try switching to the "Classic" graphics engine in SketchUp's settings .
Conflicts with Other Applications
Close out any other applications that might conflict with SketchUp, such as anti-virus software or other resource-intensive programs.
SketchUp Software Issues
Outdated Software Version
Make sure you have the latest version of SketchUp installed.
Corrupted Installation
For Windows users, you can attempt to repair your installation of SketchUp. MacOS users should reinstall SketchUp.
"BugSplat" Errors
Fill out the information in the BugSplat form and include screenshots and logs if possible.
Model and Plugin Issues
Large and Complex Models
Optimize your model. Some great tips appear in Improving Performance .
Incompatible or Outdated Plugins/Extensions
Disable or uninstall plugins one by one to identify any problematic ones.
Autosave Conflicts
Check your autosave settings . When set up incorrectly, they can cause conflicts with files stored on a network drive or in cloud storage like Trimble Connect.
Corrupted Model Files
Try opening a backup copy or creating a new model to see if the issue persists.
If you have made sure your system meets all of these requirements and have addressed each issue above but are still experiencing issues, it may be on our end. If you weren’t able to send a BugSplat report, please document what happened, what you have tried, and what the results were and reach out to the SketchUp support team .
