Importing Models, Components, and Images
Last updated: 10월 8, 2026•1 분 read.
With the Import option, available in the dropdown found in the Main Menu, you can import other 3D models of the following types into your SketchUp model:
  • .skp
  • .3ds
  • .dae
  • .dem
  • .dwg
  • .dxf
  • .kmz
  • .stl
When you attempt to import a 3D file you will be prompted to download it as a component. Once imported you can edit or change it just like you would any other component.
You can also import the following 2D file types:
  • .dwg
  • .dxf
When you attempt to import a 2D file you will be prompted to save it as an image or a material.
