Environment Panel
최종 업데이트: 9월 29, 2026•1 분 읽음.
The Environment panel helps you add or manage the environment your model is using.
The In Model tab shows any environment you have added to the scenes in your model. The Library tab contains a collection of environments you can use. For more information on how to use environments in your model, see Adding an Environment to a Model .
