The Analysis Viewer
최종 업데이트: 8월 21, 2026•2 분 읽음.
The Analysis Viewer provides a 3D environment where you can interact with your analysis results.
image analysis viewer window
The top of the window lists the scene name for the analysis along with the type of analysis you performed.
image analysis viewer top window
You can change the view of your model with the following options:
  • Top View (icon top view) displays a 2D top-down view using parallel projection.
  • Iso View (icon iso view) displays a 3D isometric view.
  • Using the dropdown, you can select a building floor in your model and narrow the view to only show that floor.
The left side of the window offers a toolbar containing the following tools:
image analysis viewer left window
  • Select (Select.png) – The default tool for interacting with your analysis.
  • Section Plane (icon section plane tool.png) – Activate and click a face on the model to create a section. You can then use the tool to adjust the view or delete a section if needed.
  • Zoom Extents (Zoom 20Extents.png) – Resets the camera to show the entire uploaded model.
The right side of the window contains the following panels to help you adjust your results:
image analysis viewer right window
  • Analysis Settings – Settings specific to each analysis allowing you to change the criteria used to generate your analysis data and adjust the settings for the simulation.
  • Spaces – Lists all floors and spaces in the model with the option to toggle each on or off.
  • Materials – Lists all materials in the model and how their properties are used in the simulation.
  • Display – Settings allowing you to toggle on or off parts of your model, how faces appear in the simulation, and what units of measurement are used.
  • Model Info – The model’s geolocation information.
The bottom of the window provides a legend appropriate to your chosen analysis type to help you interpret your analysis data.
image analysis viewer bottom window
After performing an analysis, clicking Home (icon home.png) on the Analysis Viewer opens the Analysis Hub dashboard where you can view and manage each analysis you’ve performed, create a new one, or start again with a new model snapshot.
image analysis hub dashboard window
