SketchUp Help Center
How Can We Help?
What's included with SketchUp Shop
SketchUp for Web - Free vs Shop
SketchUp Shop is the same web version of SketchUp you may have already been using. However, if you have an active subscription, then you’ll also have access to a handful of valuable new tools previously only available in SketchUp Pro (which you have to install locally on your computer).
SketchUp for Web Features Free Shop
Import Formats stl stl, dwg, dxf, dae, kmz, 3ds, dem, ddf
Export Formats stl stl, dwg, dxf, dae, kmz, 3ds, wrl, fbx, xsi, obj
Advanced Solid Tools
Outliner
Create Custom Materials
Online Storage 10GB via Trimble Connect, Personal Unlimited Storage via Trimble Connect, Business
Online Collaboration 5 Users, 1 Project via Trimble Connect, Personal Unlimited Users and Projects via Trimble Connect, Business
Note: SketchUp for Web, Shop Edition, is a subscription service. To maintain active functionality, you need to maintain an active subscription. To learn more, please visit our SketchUp Subscription Bundles.
Since SketchUp for Web does not have unrestricted access to your computer’s file system, there are some special rules to follow when working with referenced texture files in 3D model import and export formats that support them, including; dae, 3ds, wrl, fbx, xsi and obj.
Import dae, 3ds:
When importing dae or 3ds files that include referenced texture images, you must first create a folder that includes the texture images, then create a zipped archive that contains the model (at the root directory of the zip archive) and the folder of images . Be sure that the model file includes proper paths to find its texture images before zipping things up.
Once you have created the zip archive, upload that through SketchUp for Web’s Import user interface.
Export dae, 3ds, wrl, fbx, xsi, obj:
On export from SketchUp for Web, a zipped archive file will be downloaded to your local disk for models that include referenced texture images. Most importing applications will not be able to unzip this archive file without your help. To import the model, you will need to unzip the archive first.
OS:
Need Help Fast?
